この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Speakers tend to degrade with time, which can result in a loss of audio quality. Speakers can also accumulate layers of dust and debris that lessens their quality. Occasionally a speaker will altogether stop working. in each of these cases it can be helpful to remove the offending speaker. The speakers in this laptop are hard to get to but, with the proper tools and instructions can be removed.
必要な工具と部品
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Disconnect wire attaching LCD to motherboard
Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
2 の人々がこのガイドを完成させました。
