この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The motherboard is a essential part that contains the CPU and runs your computer and its systems, if its damaged then most likely it'll have to be replaced. This guide will show you how to get to the motherboard and replace it.
必要な工具と部品
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Disconnect wire attaching LCD to motherboard
Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
Remove the upper half of laptop and place bottom half in the center of your workspace.
Remove the one 2.00mm phillips screw.
Remove the ribbon cable connecting the USB ports to the motherboard.
3 の人々がこのガイドを完成させました。
