この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your keys are not typing anything or the way they should, then check this guide to see how to safely remove and replace the keyboard input device on the computer. It will also contain detailed pictures on what to expect and watch out for, such as ribbons or wires.
必要な工具と部品
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
ある他の人がこのガイドを完成しました。
