はじめに
The hard drive is the storage space of your computer, containing your music, photos, programs, and documents. It also houses your operating system. Save all the files you want to keep on an external device before installing a new hard drive, as replacing the hard drive basically gives you a new computer.
パーツ
パーツは必要ありません。
  1. Make sure your computer is turned off and the computer is not plugged in. Turn your laptop upside down, and slide the right release tab outward.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  3. Turn the laptop around 180 degrees. Unscrew the 4 mm screw with the Philips #1 screwdriver. Lift and remove the hard drive cover.
    • Turn the laptop around 180 degrees.
    • Unscrew the 4 mm screw with the Philips #1 screwdriver.
    • Lift and remove the hard drive cover.
  4. Pull on the rubber tab to slide the hard drive to the left. Pick up the near side of the hard drive and pull it out the back. Pick up the near side of the hard drive and pull it out the back.
    • Pull on the rubber tab to slide the hard drive to the left.
    • Pick up the near side of the hard drive and pull it out the back.
まとめ
ある他の人がこのガイドを完成しました。
pfedigan
メンバー登録日: 2013年04月12日
11 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S2G23
4 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 1,896
