はじめに
Usually, when the screen no longer works, the area behind the screen is also damaged. This guide shows you how to replace the screen of your Toshiba Satellite 1805-S177 laptop.
必要な工具と部品
Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
Using a Phillips screwdriver, unscrew and remove 5 screws labeled F6, located on the metal piece on the left side of the keyboard area.
2 の人々がこのガイドを完成させました。
