この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
必要な工具と部品
Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
Using a Phillips screwdriver, unscrew and remove 5 screws labeled F6, located on the metal piece on the left side of the keyboard area.
As shown by the photo, remove the small green computer part by pinching the top with your fingers and gently lift it away from the laptop.
5 の人々がこのガイドを完成させました。
