はじめに
Use this guide to replace the keyboard on your Toshiba Satellite.
  1. The battery is located on the front right corner of the laptop.
    • The battery is located on the front right corner of the laptop.
  2. With one finger on the raised grip, slide the latch towards the front of the laptop.
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Pull the battery out towards the side. Pull the battery out towards the side.
    • Pull the battery out towards the side.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Lift the battery straight up, out of the computer. Lift the battery straight up, out of the computer.
    • Lift the battery straight up, out of the computer.
  6. Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard. Fully detach the strip. Fully detach the strip.
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  7. Unscrew the two screws near the top of the keyboard. Unscrew the two screws near the top of the keyboard.
    • Unscrew the two screws near the top of the keyboard.
  8. Lift the keyboard by holding the middle top of the keyboard. The keyboard is still connected by a ribbon cable to the motherboard.
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  9. Carefully pull upwards on the ribbon cable to detach. Remove keyboard. Remove keyboard.
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
まとめ
Kiril Lange
メンバー登録日: 2014年09月22日
919 ポイント
9のガイドは作成済み
チーム
USF Tampa, Team 3-2, Brown Fall 2014 USF Tampa, Team 3-2, Brown Fall 2014人のメンバー
USFT-BROWN-F14S3G2
3 メンバー
9のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 147
