はじめに
This guide gives instructions on how to remove the fuse located on the yellow motherboard of the Toshiba SD-K740 DVD player.
必要な工具と部品
Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
Using the plastic opening tool, gently pop the fuse out of its restraining brackets.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
