メインコンテンツにスキップ
Toshiba SD-K740 Inverter Board Replacement
必要な工具と部品
  1. Toshiba SD-K740 Inverter Board Replacement, Top Panel: 手順 1、 1の画像 1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Inverter Board Replacement: 手順 2、 2の画像 1 Toshiba SD-K740 Inverter Board Replacement: 手順 2、 2の画像 2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Inverter Board Replacement: 手順 3、 1の画像 1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Inverter Board Replacement, Front Panel: 手順 4、 1の画像 1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Inverter Board Replacement: 手順 5、 1の画像 1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Inverter Board Replacement: 手順 6、 2の画像 1 Toshiba SD-K740 Inverter Board Replacement: 手順 6、 2の画像 2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Inverter Board Replacement, Inverter Board: 手順 7、 1の画像 1
    • Remove the black tie holding the two rear ribbon cables together by untwisting it.
  8. Toshiba SD-K740 Inverter Board Replacement: 手順 8、 2の画像 1 Toshiba SD-K740 Inverter Board Replacement: 手順 8、 2の画像 2
    • Remove the first of two ribbon cables connected to the motherboard by pulling vertically.
  9. Toshiba SD-K740 Inverter Board Replacement: 手順 9、 2の画像 1 Toshiba SD-K740 Inverter Board Replacement: 手順 9、 2の画像 2
    • Remove the second of two ribbon cables connected to the motherboard by pulling vertically.
  10. Toshiba SD-K740 Inverter Board Replacement: 手順 10、 1の画像 1
    • Pull the two cables to the right to disentangle from the disc drive.
    • Do not tug, pull, or force cable, it should slide out with minimal force.
  11. Toshiba SD-K740 Inverter Board Replacement: 手順 11、 1の画像 1
    • Pull power cord vertically to detach from the casing.
  12. Toshiba SD-K740 Inverter Board Replacement: 手順 12、 1の画像 1
    • Remove the three .303 inch screws attaching the inverter board to the casing using a #0 Phillips screwdriver.
  13. Toshiba SD-K740 Inverter Board Replacement: 手順 13、 1の画像 1
    • Push the inverter board forward and to the left to remove from the holding ledges.
  14. Toshiba SD-K740 Inverter Board Replacement: 手順 14、 2の画像 1 Toshiba SD-K740 Inverter Board Replacement: 手順 14、 2の画像 2
    • Lift the inverter board from the back end and pull toward you to complete removal.
終わりに
作成者
6人の作成者と共同で作成されました。
Joe Murphy
メンバー登録日: 01/20/11
542 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 1-16, Amido Winter 2011 Cal Poly, Team 1-16, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S1G16
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 2,098
