はじめに
If the computer is booting directly to the BIOS screen and there is enough RAM, then use this guide to replace the Hard Disk Drive.
必要な工具と部品
Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
Pull off the part of the case that's now loose by the indicated tab.
Use the JIS screwdriver head to remove the 3.7mm long JIS #0 screws at the base of the hard drive.
ある他の人がこのガイドを完成しました。
