メインコンテンツにスキップ
Toshiba Portege R500 Cooling Fan Replacement
必要な工具と部品
  1. Toshiba Portege R500 Cooling Fan Replacement, Battery: 手順 1、 2の画像 1 Toshiba Portege R500 Cooling Fan Replacement, Battery: 手順 1、 2の画像 2
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Toshiba Portege R500 Cooling Fan Replacement, Cooling Fan: 手順 2、 1の画像 1
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Toshiba Portege R500 Cooling Fan Replacement: 手順 3、 1の画像 1
    • Pull up on the back casing and remove it.
  4. Toshiba Portege R500 Cooling Fan Replacement: 手順 4、 1の画像 1
    • Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
  5. Toshiba Portege R500 Cooling Fan Replacement: 手順 5、 1の画像 1
    • Disconnect the fan's power connector using the rounded handle plastic opening tool.
    • The fan should now be free of the laptop and can be removed.
終わりに
作成者
4人の作成者と共同で作成されました。
JRJones
メンバー登録日: 04/19/13
169 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 2-19, Maness Spring 2013 Cal Poly, Team 2-19, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S2G19
3 メンバー
15のガイドは作成済み
2 件のコメント
Don't forget the silver compound when re-assembling
Graham Smith - 返信
If you really can’t find a replacement fan (which most people can’t) just gently clean the top of the CPU and back of the cooler fan with a cotton swab and and an alcohol wipe and gently re-apply some new thermal paste to both the top of the CPU and back of the cooler. What happens is the thermal paste dries out after a few years due to the CPU’s excessive heat thus causing the CPU to gointo thermal shutdown. My R600 works fine now and the entire job only takes 30 ~45 minutes and anyone who can use a use a small phillips screwdriver should be able to do this job without much difficulty. Just be sure to have 3 or 4 small containers to hold the different size screws and be careful as the screws are very very small and can get lost extremely easily if one is not careful. Also, clip the buds off a cotton swab and use this little stick to help you remove the CPU attachment end of the fan where it attaches to the motherboard.
wilson_mah - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 3,722
