はじめに
Replacing the keyboard on your laptop may seem daunting at first, but it is actually a relatively simple component to remove and replace. With the use of a few tools and about fifteen minutes of work, you can have a new keyboard up and running for your laptop.
必要な工具と部品
Flip the laptop over. Keep the front end facing away from you, so the battery appears at the top.
Remove the 4mm Phillips head screw in the middle of the laptop with a Phillips head #00 screwdriver.
もう少しです!
終わりに
