この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will go through the steps needed to install a new LCD panel. It's a fairly quick procedure, but it does require some care as it involves very delicate components and short wires that aren't immediately visible. This should be a fairly easy repair if you take it slowly and don't move anything around too roughly—displays are delicate components! Good luck!
必要な工具と部品
ある他の人がこのガイドを完成しました。
