メインコンテンツにスキップ
Toshiba Portege M300 LCD Replacement
必要な工具と部品
  1. Toshiba Portege M300 LCD Replacement, Battery: 手順 1、 1の画像 1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 LCD Replacement: 手順 2、 2の画像 1 Toshiba Portege M300 LCD Replacement: 手順 2、 2の画像 2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 LCD Replacement: 手順 3、 2の画像 1 Toshiba Portege M300 LCD Replacement: 手順 3、 2の画像 2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 LCD Replacement, LCD: 手順 4、 2の画像 1 Toshiba Portege M300 LCD Replacement, LCD: 手順 4、 2の画像 2
    • Use a plastic opening tool to unsnap the right hand side speaker cover.
  5. Toshiba Portege M300 LCD Replacement: 手順 5、 2の画像 1 Toshiba Portege M300 LCD Replacement: 手順 5、 2の画像 2
    • Remove the rest of the cover by sliding it to the right and lifting the right edge.
  6. Toshiba Portege M300 LCD Replacement: 手順 6、 2の画像 1 Toshiba Portege M300 LCD Replacement: 手順 6、 2の画像 2
    • Remove all eight plastic circular covers on the plastic screen bezel.
    • Only seven of these plastic covers will contain screws underneath.
    • Unscrew all seven screws with a Phillips head #000 screwdriver.
  7. Toshiba Portege M300 LCD Replacement: 手順 7、 2の画像 1 Toshiba Portege M300 LCD Replacement: 手順 7、 2の画像 2
    • Use a plastic opening tool to separate the screen bezel from the rest of the case.
    • Pull at the top edge of the LCD to separate it from the top part of the case.
    • Only separate the casing and the LCD by an inch—there are still wires connecting them.
  8. Toshiba Portege M300 LCD Replacement: 手順 8、 2の画像 1 Toshiba Portege M300 LCD Replacement: 手順 8、 2の画像 2
    • Use a Phillips #000 to unscrew the one 2.8 mm fine thread screw holding the wire connected to the right face of the LCD.
  9. Toshiba Portege M300 LCD Replacement: 手順 9、 1の画像 1
    • Flip the LCD over onto the back.
    • Gently pull the connection on the corner of the LCD to disconnect.
  10. Toshiba Portege M300 LCD Replacement: 手順 10、 2の画像 1 Toshiba Portege M300 LCD Replacement: 手順 10、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the tape connecting LCD to the inverter.
    • Use tweezers to remove the LCD cable from the inverter.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Alison Wendt
メンバー登録日: 04/18/13
135 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S21G51
3 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 16
今までの合計 1,009
