メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will go through the steps needed to install a new hard drive.
パーツ
パーツは指定されていません。
  1. Turn the computer over onto its back.
    • Turn the computer over onto its back.
  2. Slide the lock on the left side to the unlock position. Slide the lock on the right side to the unlock position until there is a clicking sound.
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Remove the battery by sliding it out while both locks remain in the unlock position. Remove the battery by sliding it out while both locks remain in the unlock position.
    • Remove the battery by sliding it out while both locks remain in the unlock position.
  4. Turn the computer over onto the back. Use a Phillips head screwdriver to remove the screw from the hard drive cover. One 8.5 mm fine thread screw.
    • Turn the computer over onto the back.
    • Use a Phillips head screwdriver to remove the screw from the hard drive cover.
    • One 8.5 mm fine thread screw.
    • Lift and remove the cover.
  5. Carefully remove the hard drive from the IDE cable by pulling on the black connector (do not pull the orange cable). Carefully remove the hard drive from the IDE cable by pulling on the black connector (do not pull the orange cable). Carefully remove the hard drive from the IDE cable by pulling on the black connector (do not pull the orange cable).
    • Carefully remove the hard drive from the IDE cable by pulling on the black connector (do not pull the orange cable).
  6. Remove the two gray rubber covers from  both ends of the hard drive. Remove the two gray rubber covers from  both ends of the hard drive.
    • Remove the two gray rubber covers from both ends of the hard drive.
終わりに
5 の人々がこのガイドを完成させました。
Alison Wendt
メンバー登録日: 2013年04月18日
114 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S21G51
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 1,798
