必要な工具と部品
Save your work.
Turn off the computer. The LED Power must not light up anymore.
Close the screen and place the computer face down as shown in the picture.
Slide the safety latch (on the left side of the picture) to the unlocked position (to the left) to activate the release.
Slide the battery release (pictured on the right) to the right side and hold it to release the battery and remove the battery from the back of the computer.
Remove the 5 marked screws and then turn the device over and open the screen.
First, we remove the cover of the Einschalteinheit by levering each other with a spatula to the left and right.
Grasp the keyboard at the top and on the left side start to lever out the keyboard with a spatula. Repeat this procedure on the right.
Hold the keyboard in this position with one hand and use the other hand and pointed tweezers to open the black retaining clips by sliding them in the direction of the ribbon cable.
Now the ribbon cable can be pulled out of the holder.
Place the keyboard securely on its work surface.
Repeat the steps in order to reassemble your device.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
irlandaさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
