メインコンテンツにスキップ
Toshiba NB205 N330PK Webcam Replacement
必要な工具と部品
  1. Toshiba NB205 N330PK Webcam Replacement, Webcam: 手順 1、 2の画像 1 Toshiba NB205 N330PK Webcam Replacement, Webcam: 手順 1、 2の画像 2
    • Use a spudger to remove the small rubber screw coverings above each retaining screw.
    • Use the bit driver with a Phillips #0 bit to remove the two 5 mm screws securing the screen bezel.
  2. Toshiba NB205 N330PK Webcam Replacement: 手順 2、 3の画像 1 Toshiba NB205 N330PK Webcam Replacement: 手順 2、 3の画像 2 Toshiba NB205 N330PK Webcam Replacement: 手順 2、 3の画像 3
    • Using a spudger, gently pry the screen bezel to the condition of the photograph.
    • For this procedure, it is not necessary to completely removal screen bezel so in order to reduce work, bezel is just partially removed.
  3. Toshiba NB205 N330PK Webcam Replacement: 手順 3、 2の画像 1 Toshiba NB205 N330PK Webcam Replacement: 手順 3、 2の画像 2
    • Using pliers, gently remove the electrical connection to the webcam by pulling the plug to the right (per orientation of the photo).
    • Allow the removed wire to hang in place but make note of alignment with respect to webcam.
    • This step is performed while holding down the bezel which is only partially detached.
  4. Toshiba NB205 N330PK Webcam Replacement: 手順 4、 3の画像 1 Toshiba NB205 N330PK Webcam Replacement: 手順 4、 3の画像 2 Toshiba NB205 N330PK Webcam Replacement: 手順 4、 3の画像 3
    • Use the spudger to pry each side of the webcam until it releases from its adhesive back.
  5. Toshiba NB205 N330PK Webcam Replacement: 手順 5、 2の画像 1 Toshiba NB205 N330PK Webcam Replacement: 手順 5、 2の画像 2
    • Position the new webcam in the old webcam's position. The webcam must be carefully aligned in order to function properly with the bezel in place. Align the hole of the webcam assembly over the cylinder of the webcam stabilizer.
    • Reconnect the electrical connection.
  6. Toshiba NB205 N330PK Webcam Replacement: 手順 6、 3の画像 1 Toshiba NB205 N330PK Webcam Replacement: 手順 6、 3の画像 2 Toshiba NB205 N330PK Webcam Replacement: 手順 6、 3の画像 3
    • Gently press the front bezel back into its original position.
    • Using the bit driver and Phillips #0 bit, drive the two bezel retaining screws in to place.
    • Cover the screws with the small covers with tweezers.
ゴール
作成者
5人の作成者と共同で作成されました。
Mason McCaskill
メンバー登録日: 10/18/13
1,000 ポイント
9のガイドは作成済み
チーム
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G2
3 メンバー
27のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 554
