メインコンテンツにスキップ
Toshiba NB205 N330PK Keyboard Replacement
必要な工具と部品
  1. Toshiba NB205 N330PK Keyboard Replacement, Power Button: 手順 1、 2の画像 1 Toshiba NB205 N330PK Keyboard Replacement, Power Button: 手順 1、 2の画像 2
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Toshiba NB205 N330PK Keyboard Replacement: 手順 2、 2の画像 1 Toshiba NB205 N330PK Keyboard Replacement: 手順 2、 2の画像 2
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 Bit, remove the two circled screws labelled F6. (These hold the keyboard) one screw may be under a rubber stopper
  3. Toshiba NB205 N330PK Keyboard Replacement: 手順 3、 2の画像 1 Toshiba NB205 N330PK Keyboard Replacement: 手順 3、 2の画像 2
    • While holding the top of the netbook, flip the netbook over.
  4. Toshiba NB205 N330PK Keyboard Replacement: 手順 4、 2の画像 1 Toshiba NB205 N330PK Keyboard Replacement: 手順 4、 2の画像 2
    • Carefully lift off the power bar assembly for access to the button and receiver.
  5. Toshiba NB205 N330PK Keyboard Replacement, Keyboard: 手順 5、 2の画像 1 Toshiba NB205 N330PK Keyboard Replacement, Keyboard: 手順 5、 2の画像 2
    • Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
  6. Toshiba NB205 N330PK Keyboard Replacement: 手順 6、 2の画像 1 Toshiba NB205 N330PK Keyboard Replacement: 手順 6、 2の画像 2
    • Reach under the keyboard and disconnect the electrical connection.
    • Lift the broken keyboard off.
  7. Toshiba NB205 N330PK Keyboard Replacement: 手順 7、 3の画像 1 Toshiba NB205 N330PK Keyboard Replacement: 手順 7、 3の画像 2 Toshiba NB205 N330PK Keyboard Replacement: 手順 7、 3の画像 3
    • Reattach the new electrical connection into the old connection location.
    • Place the keyboard into the original location starting with the bottom first.
    • Gently press the keyboard down to secure it into its original location.
ゴール
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Mason McCaskill
メンバー登録日: 10/18/13
1,021 ポイント
9のガイドは作成済み
チーム
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G2
3 メンバー
27のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 872
