メインコンテンツにスキップ
Toshiba HD-A2 Drive Belt Replacement
必要な工具と部品
  1. Toshiba HD-A2 Drive Belt Replacement, Top Panel: 手順 1、 1の画像 1
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Toshiba HD-A2 Drive Belt Replacement: 手順 2、 2の画像 1 Toshiba HD-A2 Drive Belt Replacement: 手順 2、 2の画像 2
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Toshiba HD-A2 Drive Belt Replacement: 手順 3、 1の画像 1
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  4. Toshiba HD-A2 Drive Belt Replacement, Optical Drive: 手順 4、 3の画像 1 Toshiba HD-A2 Drive Belt Replacement, Optical Drive: 手順 4、 3の画像 2 Toshiba HD-A2 Drive Belt Replacement, Optical Drive: 手順 4、 3の画像 3
    • Remove five 6mm Phillips screws with a Phillips #2 screwdriver.
    • The 2 screws on the right of the cartridge are better shown in the second and third photos.
  5. Toshiba HD-A2 Drive Belt Replacement: 手順 5、 2の画像 1 Toshiba HD-A2 Drive Belt Replacement: 手順 5、 2の画像 2
    • Remove the remaining four 6mm Phillips screws.
  6. Toshiba HD-A2 Drive Belt Replacement: 手順 6、 3の画像 1 Toshiba HD-A2 Drive Belt Replacement: 手順 6、 3の画像 2 Toshiba HD-A2 Drive Belt Replacement: 手順 6、 3の画像 3
    • Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
  7. Toshiba HD-A2 Drive Belt Replacement: 手順 7、 2の画像 1 Toshiba HD-A2 Drive Belt Replacement: 手順 7、 2の画像 2
    • Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
  8. Toshiba HD-A2 Drive Belt Replacement: 手順 8、 1の画像 1
    • Using your fingers, gently pull off the wires.
  9. Toshiba HD-A2 Drive Belt Replacement: 手順 9、 2の画像 1 Toshiba HD-A2 Drive Belt Replacement: 手順 9、 2の画像 2
    • Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
    • Be careful not to rip the tape attaching the green circuit boards together.
  10. Toshiba HD-A2 Drive Belt Replacement: 手順 10、 2の画像 1 Toshiba HD-A2 Drive Belt Replacement: 手順 10、 2の画像 2
    • Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
  11. Toshiba HD-A2 Drive Belt Replacement: 手順 11、 2の画像 1 Toshiba HD-A2 Drive Belt Replacement: 手順 11、 2の画像 2
    • Using your hands, gently lift the lid and carefully place it aside.
  12. Toshiba HD-A2 Drive Belt Replacement: 手順 12、 3の画像 1 Toshiba HD-A2 Drive Belt Replacement: 手順 12、 3の画像 2 Toshiba HD-A2 Drive Belt Replacement: 手順 12、 3の画像 3
    • Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
  13. Toshiba HD-A2 Drive Belt Replacement, Drive Belt: 手順 13、 3の画像 1 Toshiba HD-A2 Drive Belt Replacement, Drive Belt: 手順 13、 3の画像 2 Toshiba HD-A2 Drive Belt Replacement, Drive Belt: 手順 13、 3の画像 3
    • Slide out the disc tray. If it's stuck, turn the white gear to the right to release the tray.
  14. Toshiba HD-A2 Drive Belt Replacement: 手順 14、 1の画像 1
    • The drive belt is the black rubber band.
  15. Toshiba HD-A2 Drive Belt Replacement: 手順 15、 2の画像 1 Toshiba HD-A2 Drive Belt Replacement: 手順 15、 2の画像 2
    • Using your fingers, gently remove the drive belt.
    • If you have difficulty using your fingers, use a prying tool.
終わりに
作成者
1人の作成者と共同作成されました。
Nouriyah Saleh
メンバー登録日: 10/22/18
800 ポイント
6のガイドは作成済み
チーム
UC Davis, Team S11-G1, Lore Fall 2018 UC Davis, Team S11-G1, Lore Fall 2018人のメンバー
UCD-LORE-F18S11G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 402
