メインコンテンツにスキップ
Toshiba Excite 7 Battery Removal
必要な工具と部品
  1. Toshiba Excite 7 Battery Removal, Battery Removal: 手順 1、 3の画像 1 Toshiba Excite 7 Battery Removal, Battery Removal: 手順 1、 3の画像 2 Toshiba Excite 7 Battery Removal, Battery Removal: 手順 1、 3の画像 3
    • Remove the back cover.
    • Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
    • After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
  2. Toshiba Excite 7 Battery Removal, Remove Tape: 手順 2、 2の画像 1 Toshiba Excite 7 Battery Removal, Remove Tape: 手順 2、 2の画像 2
    • Remove any black tape from the device.
    • Keep the tape, you will need to put it back on when you are done.
  3. Toshiba Excite 7 Battery Removal, Unplug Wires: 手順 3、 2の画像 1 Toshiba Excite 7 Battery Removal, Unplug Wires: 手順 3、 2の画像 2
    • Unplug the wires from the battery.
    • The battery is the black rectangle in the middle of the device. The device has two wiring harnesses attached to it, one just above the battery and one just to the right.
  4. Toshiba Excite 7 Battery Removal, remove screws: 手順 4、 2の画像 1 Toshiba Excite 7 Battery Removal, remove screws: 手順 4、 2の画像 2
    • Unscrew the battery from the device.
    • The device has 5 screws to remove, keep the screws.
  5. Toshiba Excite 7 Battery Removal, Unclip and remove battery: 手順 5、 2の画像 1 Toshiba Excite 7 Battery Removal, Unclip and remove battery: 手順 5、 2の画像 2
    • The battery has one clip you will need to remove. The clip is located at the bottom right corner of the battery just above the right speaker. The speakers and wires are not secured to the battery, they may fall off.
    • Push the clip back then lift the battery up.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
osmel fermin
メンバー登録日: 01/15/15
176 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-3, Tanski Winter 2015 USF Tampa, Team 1-3, Tanski Winter 2015人のメンバー
USFT-TANSKI-W15S1G3
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,748
