はじめに
If the rear facing camera on your Toshiba Excite 10 AT300 is now longer functioning, replacement isn't difficult and this guide will give you the step by step procedure. It involves removing a screw, a ribbon cable, and several copper foil wires.
  1. Remove the SD card from the SD card slot.
    • Remove the SD card from the SD card slot.
  2. Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device. Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet. Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out. Be careful not to rip the wires out of the white connector piece. Be careful not to rip the wires out of the white connector piece.
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
  4. Using a #00 Phillips screwdriver, remove the following screws: Five 3mm Phillips #00 screws
    • Using a #00 Phillips screwdriver, remove the following screws:
      • Five 3mm Phillips #00 screws
  5. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Gently lift the battery, pulling away from the tab holding it in place at the bottom. While holding the battery up, use a pair of tweezers to remove the battery cable from its connector. While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
    • Gently lift the battery, pulling away from the tab holding it in place at the bottom.
    • While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
  7. Using a #00 Philips screwdriver, remove the screw attaching daughter board.
    • Using a #00 Philips screwdriver, remove the screw attaching daughter board.
    • Remove the yellow tape using a pair of tweezers.
  8. Unlock the ribbon cable housing using tweezers and/or a spudger. Gently pull the ribbon cable out of its housing using the tweezers or your hands. Gently pull the ribbon cable out of its housing using the tweezers or your hands.
    • Unlock the ribbon cable housing using tweezers and/or a spudger.
    • Gently pull the ribbon cable out of its housing using the tweezers or your hands.
  9. Pull copper tape away from the back, keeping it connected to the green rear camera board. Be careful not to rip the copper tape. Be careful not to rip the copper tape.
    • Pull copper tape away from the back, keeping it connected to the green rear camera board.
    • Be careful not to rip the copper tape.
  10. Using your hands remove daughter board by lifting it off of the tablet chassis. Flip it over and place it next to the tablet face-down. Do not disconnect the red and black wires connecting it to the vibrating mechanism.
    • Using your hands remove daughter board by lifting it off of the tablet chassis. Flip it over and place it next to the tablet face-down.
    • Do not disconnect the red and black wires connecting it to the vibrating mechanism.
  11. Gently pinch the ribbon cable connector between two fingers or with tweezers and pull it straight outwards. The ribbon cable connector should disconnect and the camera can now be replaced. Gently pinch the ribbon cable connector between two fingers or with tweezers and pull it straight outwards. The ribbon cable connector should disconnect and the camera can now be replaced.
    • Gently pinch the ribbon cable connector between two fingers or with tweezers and pull it straight outwards. The ribbon cable connector should disconnect and the camera can now be replaced.
まとめ
Gus Holz
メンバー登録日: 2014年10月09日
297 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 14-26, Maness Fall 2014 Cal Poly, Team 14-26, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S14G26
4 メンバー
12のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 421
