はじめに
If the front facing camera on your Toshiba Excite 10 AT300 is now longer functioning, replacement isn't difficult and this guide will give you the step by step procedure. It involves removing a single copper foil wire.
必要な工具と部品
Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
Using a #00 Phillips screwdriver, remove the following screws:
Five 3mm Phillips #00 screws
Carefully remove the ribbon cable from the housing by pulling gently upwards on the sides of the cable housing. The cable should come straight up off of its housing.
