メインコンテンツにスキップ
Toshiba Encore WT8-A Battery Replacement
必要な工具と部品
  1. Toshiba Encore WT8-A Battery Replacement, Battery: 手順 1、 1の画像 1
    • Use the metal spudger to create a gap between the back cover and the device.
    • Be gentle when using the metal spudger so that the casing is not damaged.
  2. Toshiba Encore WT8-A Battery Replacement: 手順 2、 2の画像 1 Toshiba Encore WT8-A Battery Replacement: 手順 2、 2の画像 2
    • Use the nylon spudger to completely separate the back of the device.
    • Take the nylon spudger around the outside of the device cover until it comes free.
  3. Toshiba Encore WT8-A Battery Replacement: 手順 3、 2の画像 1 Toshiba Encore WT8-A Battery Replacement: 手順 3、 2の画像 2
    • Use the Phillips head PH0 to remove the 7 battery screws.
    • The 5 side screws measure 3.5mm.
    • The 2 top and bottom screws measure 4.5 mm.
  4. Toshiba Encore WT8-A Battery Replacement: 手順 4、 2の画像 1 Toshiba Encore WT8-A Battery Replacement: 手順 4、 2の画像 2
    • To disconnect the cable, use the fine tweezers to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • The zero insertion force (ZIF) connector is used to secure delicate ribbon cables, such as this trackpad cable.
  5. Toshiba Encore WT8-A Battery Replacement: 手順 5、 1の画像 1
    • Remove the colored power cable from its connector.
    • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Be sure to be very gentle when prying colored wires from motherboard to ensure that there is no damage.
  6. Toshiba Encore WT8-A Battery Replacement: 手順 6、 1の画像 1
    • Battery will lift out of the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Zachary Armstrong
メンバー登録日: 09/15/16
293 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 17-4, Blackwell Fall 2016 USF Tampa, Team 17-4, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S17G4
3 メンバー
8のガイドは作成済み
3 件のコメント
Hi can I get Battery for Toshiba Encore 2 WT8-B?
Thanks
Regards
Dr Ravindra
Ravindra MIstry - 返信
Hi friends can I get Battery for Toshiba Encore 2 WT8-B
Thanks
Regards
Dr Ravindra
who can I replacement socket charging for toshiba tablet WT8-A
monzer daoud - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 4,984
