はじめに
The following guide gives instructions on how to remove the motherboard. This procedure is done in order to replace multiple components. Be sure to avoid damaging any components or connectors removed from the motherboard. It is advised to back up data to an external device before attempting any component replacement.
必要な工具と部品
Using the flat end of the spudger, gently pry open the back case from the rest of the device.
もう少しです!
終わりに
