はじめに
The Toshiba Encore Mini is equipped with a built-in front-facing camera and a built-in rear-facing camera. Before replacing either camera, we recommend you back-up any photos (or other data) to an external storage device. Also, you will need a good place to keep track of five very small screws, as you will need them for reassembly.
必要な工具と部品
Using the flat end of the spudger, gently pry open the back case from the rest of the device.
もう少しです!
終わりに
