メインコンテンツにスキップ
Toshiba Dynabook T552-58G Hard Drive Replacement
必要な工具と部品
  1. Toshiba Dynabook T552-58G Hard Drive Replacement, Back Panel: 手順 1、 1の画像 1
    • Turn the Toshiba Dynabook T552-58G so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 2、 2の画像 1 Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 2、 2の画像 2
    • Remove the 10 screws located on the back panel of the Toshiba Dynabook T552-58G using a PH 0 screwdriver.
    • Each screw will be 5.3 mm long.
  3. Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 3、 3の画像 1 Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 3、 3の画像 2 Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 3、 3の画像 3
    • Remove the black screw using the J0 screwdriver. This is located by the top right foot of the device.
    • This will allow removal of the hard drive cover.
    • This screw will not come out of the hard drive cover.
  4. Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 4、 1の画像 1
    • Remove the single screw located below the hard drive using the J0 screwdriver. This screw is 5.3 mm long.
  5. Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 5、 3の画像 1 Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 5、 3の画像 2 Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 5、 3の画像 3
    • Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
    • Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
  6. Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 6、 3の画像 1 Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 6、 3の画像 2 Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 6、 3の画像 3
    • Slowly lift the back panel away from the computer.
    • There should be some resistance.
    • Once lifted, carefully remove the back panel.
  7. Toshiba Dynabook T552-58G Hard Drive Replacement, Hard Drive: 手順 7、 1の画像 1
    • The hard drive is located in the under the L-shaped panel on the back of the computer.
  8. Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 8、 1の画像 1
    • Carefully push the hard drive to the left
  9. Toshiba Dynabook T552-58G Hard Drive Replacement: 手順 9、 1の画像 1
    • Gently lift the hard drive using your fingers.
終わりに
作成者
2人の作成者と共同で作成されました。
Laney Pilkington
メンバー登録日: 01/31/19
329 ポイント
2のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 550
