はじめに
This guide will walk you through the process of replacing a fan in the Toshiba Dynabook T552-58G. You will need to replace the fan if it is faulty or broken. There are a few tools required for this guide.
必要な工具と部品
Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
