メインコンテンツにスキップ
Toshiba Chromebook 2 Touchpad Replacement
必要な工具と部品
  1. Toshiba Chromebook 2 Touchpad Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Touchpad Replacement: 手順 2、 1の画像 1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Touchpad Replacement: 手順 3、 2の画像 1 Toshiba Chromebook 2 Touchpad Replacement: 手順 3、 2の画像 2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Touchpad Replacement: 手順 4、 2の画像 1 Toshiba Chromebook 2 Touchpad Replacement: 手順 4、 2の画像 2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Touchpad Replacement: 手順 5、 1の画像 1
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Touchpad Replacement, Battery: 手順 6、 2の画像 1 Toshiba Chromebook 2 Touchpad Replacement, Battery: 手順 6、 2の画像 2
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Touchpad Replacement: 手順 7、 2の画像 1 Toshiba Chromebook 2 Touchpad Replacement: 手順 7、 2の画像 2
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Touchpad Replacement: 手順 8、 1の画像 1
    • Remove the battery by gently pulling up on the bottom corners.
  9. Toshiba Chromebook 2 Touchpad Replacement, Speakers: 手順 9、 1の画像 1
    • Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
  10. Toshiba Chromebook 2 Touchpad Replacement: 手順 10、 3の画像 1 Toshiba Chromebook 2 Touchpad Replacement: 手順 10、 3の画像 2 Toshiba Chromebook 2 Touchpad Replacement: 手順 10、 3の画像 3
    • Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
  11. Toshiba Chromebook 2 Touchpad Replacement: 手順 11、 1の画像 1
    • Remove the speakers by lifting upwards.
    • Wiring connecting the left and right speakers may be taped to the top of the battery. Simply remove the tape to remove the speakers.
  12. Toshiba Chromebook 2 Touchpad Replacement, Touchpad: 手順 12、 2の画像 1 Toshiba Chromebook 2 Touchpad Replacement, Touchpad: 手順 12、 2の画像 2
    • Detach the ribbon cable connected to the motherboard by gently pulling near the top fold.
  13. Toshiba Chromebook 2 Touchpad Replacement: 手順 13、 1の画像 1
    • Detach the ribbon cable connected to the touch pad by gently pulling near the bottom fold.
  14. Toshiba Chromebook 2 Touchpad Replacement: 手順 14、 2の画像 1 Toshiba Chromebook 2 Touchpad Replacement: 手順 14、 2の画像 2
    • Remove all four 3.70mm screws around the edges of the touchpad using a Phillips #0 screwdriver.
  15. Toshiba Chromebook 2 Touchpad Replacement: 手順 15、 2の画像 1 Toshiba Chromebook 2 Touchpad Replacement: 手順 15、 2の画像 2
    • Use the spudger to push up on the metal cover below the touch pad until it reaches 90 degrees then pull up to detach.
  16. Toshiba Chromebook 2 Touchpad Replacement: 手順 16、 3の画像 1 Toshiba Chromebook 2 Touchpad Replacement: 手順 16、 3の画像 2 Toshiba Chromebook 2 Touchpad Replacement: 手順 16、 3の画像 3
    • Peel back the aluminum foil piece on the top right corner of the touchpad.
    • Move slowly and carefully, you will need the same aluminum foil piece to connect to your new touchpad.
  17. Toshiba Chromebook 2 Touchpad Replacement: 手順 17、 2の画像 1 Toshiba Chromebook 2 Touchpad Replacement: 手順 17、 2の画像 2
    • Push down on the bottom right corner and slowly lift up in the upper right hand corner until the touch pad comes out.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Haley Hattendorf
メンバー登録日: 10/06/16
598 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S10G4
4 メンバー
11のガイドは作成済み
2 件のコメント
Thanks for this guide! Worked perfectly.
Mathias Maes - 返信
This is great! I was able to save our school the cost of a replacement computer!
Tiger Prior - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,811
