メインコンテンツにスキップ
Toshiba Chromebook 2 Speakers Replacement
必要な工具と部品
  1. Toshiba Chromebook 2 Speakers Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Speakers Replacement: 手順 2、 1の画像 1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Speakers Replacement: 手順 3、 2の画像 1 Toshiba Chromebook 2 Speakers Replacement: 手順 3、 2の画像 2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Speakers Replacement: 手順 4、 2の画像 1 Toshiba Chromebook 2 Speakers Replacement: 手順 4、 2の画像 2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Speakers Replacement: 手順 5、 1の画像 1
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Speakers Replacement, Battery: 手順 6、 2の画像 1 Toshiba Chromebook 2 Speakers Replacement, Battery: 手順 6、 2の画像 2
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Speakers Replacement: 手順 7、 2の画像 1 Toshiba Chromebook 2 Speakers Replacement: 手順 7、 2の画像 2
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Speakers Replacement: 手順 8、 1の画像 1
    • Remove the battery by gently pulling up on the bottom corners.
  9. Toshiba Chromebook 2 Speakers Replacement, Speakers: 手順 9、 1の画像 1
    • Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
  10. Toshiba Chromebook 2 Speakers Replacement: 手順 10、 3の画像 1 Toshiba Chromebook 2 Speakers Replacement: 手順 10、 3の画像 2 Toshiba Chromebook 2 Speakers Replacement: 手順 10、 3の画像 3
    • Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
  11. Toshiba Chromebook 2 Speakers Replacement: 手順 11、 1の画像 1
    • Remove the speakers by lifting upwards.
    • Wiring connecting the left and right speakers may be taped to the top of the battery. Simply remove the tape to remove the speakers.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alec Marnoch
メンバー登録日: 10/06/16
242 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S10G4
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 753
