メインコンテンツにスキップ
Toshiba Canvio Connect V73600-C Disassembly
必要な工具と部品
  1. Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: 手順 1、 2の画像 1 Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: 手順 1、 2の画像 2
    • On the side of your hard drive casing, insert a spudger.
    • This can be tricky as the tolerances are quite tight.
    • I used a needle to make the gap big enough to insert a pick.
  2. Toshiba Canvio Connect V73600-C Disassembly, Continue opening: 手順 2、 1の画像 1
    • Slide your spudger along the gap in the casing you made in the previous step, continuing to open the device.
  3. Toshiba Canvio Connect V73600-C Disassembly, Keep going: 手順 3、 1の画像 1
    • Slide the spudger around the corner of the casing to start opening the next side.
    • There may be a gap big enough to see the plastic clips holding the device together.
  4. Toshiba Canvio Connect V73600-C Disassembly, Prise the casing open: 手順 4、 1の画像 1
    • Once there is a big enough gap in the casing, gently prise the two parts away from each other, being sure not to break any clips.
    • This will reveal the hard drive in the casing.
  5. Toshiba Canvio Connect V73600-C Disassembly, Extract the hard drive: 手順 5、 1の画像 1
    • Simply lift the drive out of the case.
    • There may be some friction due to the anti-shock rubber on the corners of the drive.
    • Gently pry with a plastic pry tool if required.
  6. Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: 手順 6、 3の画像 1 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: 手順 6、 3の画像 2 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: 手順 6、 3の画像 3
    • As the drive has a USB port soldered directly to its logic board, instead of a converter board in between, disassembling this device seems to be pointless unless the hard drive is being used for parts.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
CONVERSION
メンバー登録日: 03/07/20
1,282 ポイント
8のガイドは作成済み
チーム
Australia Australia人のメンバー
Community
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 29
過去 30 日: 133
今までの合計 5,117
