メインコンテンツにスキップ
Toshiba CB35-C3300 Chromebook 2 Motherboard Replacement
必要な工具と部品
  1. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement, WLAN Wi-Fi PCB: 手順 1、 1の画像 1
    • Remove the two rubber tabs near the front of the computer with a metal spudger and with PH0 Phillips head screwdriver, carefully remove all ten screws and place in a safe location.
  2. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: 手順 2、 1の画像 1
    • Ensure that there is no debris, dust, or any other foreign materials blocking the Wi-Fi PCB.
  3. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: 手順 3、 1の画像 1
    • Carefully peel back the yellow tape by either folding it back or removing it entirely. Use the same PH0 Phillips head screwdriver to remove the single screw that connects the motherboard to the Wi-Fi PCB.
  4. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: 手順 4、 1の画像 1
    • When the screw has been removed, the board will naturally spring up. Carefully apply light pressure to back the PCB out of its port.
  5. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: 手順 5、 1の画像 1
    • Disconnect the black wire that is plugged onto the 1 or AUX terminal by simply lightly pulling it from the board.
  6. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: 手順 6、 1の画像 1
    • Disconnect the white wire from the 2 or Main plug by lightly pulling it from the PCB.
  7. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement, Motherboard: 手順 7、 1の画像 1
    • Use metal spudger tool to release the lever that holds the data cable to the board.
  8. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: 手順 8、 1の画像 1
    • Disconnect the speaker wire by gently pulling it out of the port.
  9. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: 手順 9、 1の画像 1
    • Remove all three cables with a spudger that were hidden by the battery.
  10. Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: 手順 10、 2の画像 1 Toshiba CB35-C3300 Chromebook 2 Motherboard  Replacement: 手順 10、 2の画像 2
    • Remove motherboard from within the laptop.
終わりに
作成者
1人の作成者と共同作成されました。
Ongela Helm
メンバー登録日: 11/26/18
109 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S6-G6, Wilson Fall 2018 IUPUI, Team S6-G6, Wilson Fall 2018人のメンバー
IUPUI-WILSON-F18S6G6
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 9
今までの合計 279
