メインコンテンツにスキップ
Toshiba CB35-C3300 Chromebook 2 Battery Replacement
必要な工具と部品
  1. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Back Cover: 手順 1、 2の画像 1 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Back Cover: 手順 1、 2の画像 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 2、 2の画像 1 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 2、 2の画像 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 3、 1の画像 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 4、 2の画像 1 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 4、 2の画像 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Battery: 手順 5、 2の画像 1 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Battery: 手順 5、 2の画像 2
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 6、 2の画像 1 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 6、 2の画像 2
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 7、 3の画像 1 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 7、 3の画像 2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 7、 3の画像 3
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 8、 2の画像 1 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 手順 8、 2の画像 2
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
varun kapadia
メンバー登録日: 10/18/17
219 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S1-G121, Cagle Fall 2017 USF Tampa, Team S1-G121, Cagle Fall 2017人のメンバー
USFT-CAGLE-F17S1G121
3 メンバー
14のガイドは作成済み
コメント 1 件
Thanks again IFIXIT!!! Repaced battery on Toshiba C35 C3300 with your HELP. Guy Rogers
Guy Rogers - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,229
