メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Apple Watch キット
    スクリーンとバッテリー の修理が簡単にできます。
    ショップを見る
    Apple Watch キット
    ショップを見る
  4. If needed, use the flathead screwdriver to gently pry the panel from the phone. Using your fingers, lift the panel from the device.
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  5. Use your fingers to gently detach the ribbon wire from the logic board. Use your fingers to gently detach the ribbon wire from the logic board. Use your fingers to gently detach the ribbon wire from the logic board.
    • Use your fingers to gently detach the ribbon wire from the logic board.
  6. Use the flathead screwdriver to pry the logic board and keypad from the device. Use the flathead screwdriver to pry the logic board and keypad from the device.
    • Use the flathead screwdriver to pry the logic board and keypad from the device.
  7. Use your thumb to peel the keypad from the device. Use your thumb to peel the keypad from the device.
    • Use your thumb to peel the keypad from the device.
まとめ
Christopher
メンバー登録日: 2010年04月22日
90 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S16G6
4 メンバー
16のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,513
