はじめに
Check to see if anything is obstructing the wheel before referring to this guide.
必要な工具と部品
Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
