はじめに
This guide shows how to remove and replace the right belt pulley on the Toro Walk Behind Mower 21199HD 2018.
必要な工具と部品
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Chock the rear wheels to prevent the mower from rolling during service.
While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
Remove the grass bag.
Use a 3/8-inch socket to remove the four bolts securing the belt guard:
Three 1 inch-long recessed bolts
One 1 1/2 inch-long bolt
Loosen, but don't remove, the belt tensioner to give the belt some slack.
Use a flathead screwdriver to pry off the plastic plug cap.
Remove the plug cap.
Use a 3/8 inch socket to remove the four bolts securing the upper belt guide to the pulley.
Lift the belt up and over the left sprocket.
Move the belt to the front of the mower, out of the way of the belt tensioner.
Spin the left sprocket, with the blade attached underneath, until it is in a safe position, then place the belt on the sprocket.
Spin both blades to ensure they don't touch during a 360˚ rotation.
Use a 1/2 inch socket with a 1/2 inch wrench to remove the tensioner bolt and nut.
