はじめに
Follow this guide to replace the cutter head on a 2017 Toro Stump Grinder model 22615HD.
You will need a second person to assist with this repair.
必要な工具と部品
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Tilt the machine so that it is resting on the handle with the cutter wheel raised.
Use a 14 mm socket to remove the fasteners securing the belt guard:
One 10 mm bolt
One 10 mm nut
Use a 9/16 inch socket to loosen the four nuts securing the bottom of the motor enough to allow the motor to slide freely. Do not remove the nuts.
Use a 1/2 inch wrench in combination with the socket wrench to hold the bolts in place.
Use an impact wrench with a 9/16 inch socket to remove the bolt and washer securing the centrifugal clutch to the spindle.
手順16 Remove the pulley
注意: 手順 16-18 は、作業進行中としてマークされている ガイド から引用されています。
Use a 1/8 inch hex key to remove the pulley set screw.
Use a 9/16 inch socket to remove the two bolts and washers securing the guard plate to the motor.
Use a 9/16 inch socket to remove the four bolts from the frame.
5 の人々がこのガイドを完成させました。
