メインコンテンツにスキップ
Toro 22-Inch Recycler Lawn Mower Blade Replacement
必要な工具と部品
  1. Toro 22-Inch Recycler Lawn Mower Blade Replacement, Blade: 手順 1、 1の画像 1
    • Place the lawnmower on its side.
    • Drain the gas, and make sure the lawnmower is tilted so the oil dip stick is down.
    • Oil can't seep into the air filter if the oil dip stick is down. Draining the gas tank is important to prevent gas from being spilled.
  2. Toro 22-Inch Recycler Lawn Mower Blade Replacement: 手順 2、 1の画像 1
    • Remove the sparkplug wire from the sparkplug.
    • This will prevent the lawnmower from starting during the repair.
  3. Toro 22-Inch Recycler Lawn Mower Blade Replacement: 手順 3、 2の画像 1 Toro 22-Inch Recycler Lawn Mower Blade Replacement: 手順 3、 2の画像 2
    • Use a sturdy object, such as a brick or piece of wood, to keep the blade stable.
    • If using a brick or similar object, place it on the right side of the blade because we'll be turning the socket wrench to the left.
    • If using a piece of wood, place it across the bottom of the mower, so that the right side of the wood is wedged against the blade.
    • A small piece of wood is the most common way to stabilize the blade.
  4. Toro 22-Inch Recycler Lawn Mower Blade Replacement: 手順 4、 1の画像 1
    • A socket wrench loosens the blade attachments. Attach a 5/8-inch bit to the socket wrench, and we're ready to loosen the nut.
  5. Toro 22-Inch Recycler Lawn Mower Blade Replacement: 手順 5、 1の画像 1
    • Loosen the nut using a wrench with a 5/8-inch socket.
    • Consider wearing a pair of gloves for protection before using the wrench.
  6. Toro 22-Inch Recycler Lawn Mower Blade Replacement: 手順 6、 1の画像 1
    • Remove the blade support and pull the blade.
終わりに
作成者
1人の作成者と共同作成されました。
Mike Marshall
メンバー登録日: 09/03/23
133 ポイント
1ガイドが承認済み
チーム
University of North Alabama, Team 23-23, Winner Fall 2023 University of North Alabama, Team 23-23, Winner Fall 2023人のメンバー
UNA-WINNER-F23S23G23
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 53
過去 30 日: 169
今までの合計 342
