はじめに
If the top cover of your Logitech MBJ58 Mouse is damaged or needs to be replaced, this guide will help you replace the top cover. By replacing the top cover, damage can be removed, comfort can be added, and the aesthetics of your mouse can be increased. For this repair, no special skills are required and should be a straightforward fix. When reattaching the new cover, be sure to not strip the screw and crack the cover by using too much pressure.
必要な工具と部品
Hold the mouse so that the bottom is facing up.
Remove the single Phillips #1 screw from the bottom half of the mouse.
Place the mouse so that the bottom is resting against a hard surface.
Lift the top cover of the mouse gently, and remove it.
The cover doesn’t lift straight up on my model - once you raise the back slightly as shown, gently pull it backward (parallel to the table top, away from the cord) to disengage two plastic clips that connect the bottom to the top.
3 の人々がこのガイドを完成させました。
باز کردن پیچ زیر موس
h sh - 返信
There may be a sticker covering the screw hole.
Eric Jensen - 返信
