メインコンテンツにスキップ
TomTom XL Screen and Motherboard Replacement
必要な工具と部品
  1. TomTom XL Screen and Motherboard Replacement, Screen and Motherboard: 手順 1、 1の画像 1
    • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
    • Starting at the corners, carefully pry up the screen bezel.
  2. TomTom XL Screen and Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the four Phillips #00 screws around the edge of the screen.
  3. TomTom XL Screen and Motherboard Replacement: 手順 3、 3の画像 1 TomTom XL Screen and Motherboard Replacement: 手順 3、 3の画像 2 TomTom XL Screen and Motherboard Replacement: 手順 3、 3の画像 3
    • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
    • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
    • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
    • Remove the frame from the housing.
  4. TomTom XL Screen and Motherboard Replacement: 手順 4、 2の画像 1 TomTom XL Screen and Motherboard Replacement: 手順 4、 2の画像 2
    • Lifting from the upper edge of the screen, tilt the screen away from the device.
    • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
  5. TomTom XL Screen and Motherboard Replacement: 手順 5、 2の画像 1 TomTom XL Screen and Motherboard Replacement: 手順 5、 2の画像 2
    • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
    • Two Phillips #00 screws are located at the bottom of the first picture.
    • The third screw is hidden under the orange ribbon cable, near the screen.
    • You may have to carefully lift the screen in order to reach this screw.
  6. TomTom XL Screen and Motherboard Replacement: 手順 6、 2の画像 1 TomTom XL Screen and Motherboard Replacement: 手順 6、 2の画像 2
    • Flip the screen and motherboard over.
    • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
    • Disconnect the speaker cable connector from the motherboard.
    • Remove the motherboard and screen from the housing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
10人の作成者と共同で作成されました。
Adam Johnson
メンバー登録日: 04/21/10
122 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 33-84, Johann Spring 2010 Cal Poly, Team 33-84, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S33G84
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 9,030
