メインコンテンツにスキップ
TomTom XL Screen Replacement
必要な工具と部品
  1. TomTom XL Screen Replacement, Screen and Motherboard: 手順 1、 1の画像 1
    • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
    • Starting at the corners, carefully pry up the screen bezel.
  2. TomTom XL Screen Replacement: 手順 2、 1の画像 1
    • Remove the four Phillips #00 screws around the edge of the screen.
  3. TomTom XL Screen Replacement: 手順 3、 3の画像 1 TomTom XL Screen Replacement: 手順 3、 3の画像 2 TomTom XL Screen Replacement: 手順 3、 3の画像 3
    • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
    • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
    • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
    • Remove the frame from the housing.
  4. TomTom XL Screen Replacement: 手順 4、 2の画像 1 TomTom XL Screen Replacement: 手順 4、 2の画像 2
    • Lifting from the upper edge of the screen, tilt the screen away from the device.
    • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
  5. TomTom XL Screen Replacement: 手順 5、 2の画像 1 TomTom XL Screen Replacement: 手順 5、 2の画像 2
    • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
    • Two Phillips #00 screws are located at the bottom of the first picture.
    • The third screw is hidden under the orange ribbon cable, near the screen.
    • You may have to carefully lift the screen in order to reach this screw.
  6. TomTom XL Screen Replacement: 手順 6、 2の画像 1 TomTom XL Screen Replacement: 手順 6、 2の画像 2
    • Flip the screen and motherboard over.
    • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
    • Disconnect the speaker cable connector from the motherboard.
    • Remove the motherboard and screen from the housing.
  7. TomTom XL Screen Replacement, Screen: 手順 7、 3の画像 1 TomTom XL Screen Replacement, Screen: 手順 7、 3の画像 2 TomTom XL Screen Replacement, Screen: 手順 7、 3の画像 3
    • Using your thumbs or the flat end of a spudger, push back the white tabs on the display cable ZIF connector.
    • Gently pull the orange display cable out of the ZIF connector.
    • The display cable should slide out easily, but it may still have some adhesive on the underside. If you feel resistance, gently lift up on the ribbon cable while pulling it from the socket.
終わりに
作成者
1人の作成者と共同作成されました。
Adam Johnson
メンバー登録日: 04/21/10
122 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 33-84, Johann Spring 2010 Cal Poly, Team 33-84, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S33G84
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,306
