メインコンテンツにスキップ
TomTom VIA 1605TM Front Screen Replacement
必要な工具と部品
  1. TomTom VIA 1605TM Front Screen Replacement, Front Screen: 手順 1、 3の画像 1 TomTom VIA 1605TM Front Screen Replacement, Front Screen: 手順 1、 3の画像 2 TomTom VIA 1605TM Front Screen Replacement, Front Screen: 手順 1、 3の画像 3
    • Locate the round suction cup on the back of the device.
    • Twist the suction cup clockwise or counterclockwise while pulling back away from the device closer to your body until removed.
    • When reassembling twist the suction cup but, push in as oppose to pulling out.
  2. TomTom VIA 1605TM Front Screen Replacement: 手順 2、 1の画像 1
    • Location of screw is where the suction cup was.
    • Insert 8mm Hex #T6 screw driver into screw.
    • Unscrew in counter clockwise direction.
    • When reassembling screw in the clockwise direction.
  3. TomTom VIA 1605TM Front Screen Replacement: 手順 3、 2の画像 1 TomTom VIA 1605TM Front Screen Replacement: 手順 3、 2の画像 2
    • Pry along the edges with the plastic opening tool to separate the back and front panel.
    • Try not to tear the screen open as you may break the part. Go about this gently but with enough force to remove the screen.
  4. TomTom VIA 1605TM Front Screen Replacement: 手順 4、 3の画像 1 TomTom VIA 1605TM Front Screen Replacement: 手順 4、 3の画像 2 TomTom VIA 1605TM Front Screen Replacement: 手順 4、 3の画像 3
    • Place the new front panel (with new screen) on to the back panel. Press firmly along the edges to attach.
    • Only do this step of placing the front panel on if you are completed. If there are still components needed replacing postpone this step until the end.
終わりに
To reassemble your device, follow these instructions in reverse order. Now you're done and your device is ready to use!
作成者
2人の作成者と共同で作成されました。
Tyler Wade
メンバー登録日: 10/15/15
362 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 4-4, Catania Fall 2015 UMass Dartmouth, Team 4-4, Catania Fall 2015人のメンバー
UMASSD-CATANIA-F15S4G4
4 メンバー
5のガイドは作成済み
コメント 1 件
where can I purchase a front screen for my tom tom via 1605 TM
curtisibley - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 8
今までの合計 944
