メインコンテンツにスキップ
TomTom ONE Screen Replacement
必要な工具と部品
  1. TomTom ONE Screen Replacement, Screen: 手順 1、 1の画像 1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Screen Replacement: 手順 2、 2の画像 1 TomTom ONE Screen Replacement: 手順 2、 2の画像 2
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Screen Replacement: 手順 3、 1の画像 1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Screen Replacement: 手順 4、 1の画像 1
    • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Screen Replacement: 手順 5、 1の画像 1
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  6. TomTom ONE Screen Replacement: 手順 6、 2の画像 1 TomTom ONE Screen Replacement: 手順 6、 2の画像 2
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  7. TomTom ONE Screen Replacement: 手順 7、 1の画像 1
    • Once separated, use the spudger to pry around the edges of the outer casing.
  8. TomTom ONE Screen Replacement: 手順 8、 2の画像 1 TomTom ONE Screen Replacement: 手順 8、 2の画像 2
    • Apply pressure with thumbs to remove screen from inner casing.
    • The screen and front cover are now disconnected.
ゴール
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Alex Cauvy
メンバー登録日: 04/18/10
41 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S7G7
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 9,800
