ガイド紹介
Batteries do not last forever, so this guide is to show you how to replace the battery.
パーツ
パーツは指定されていません。
  1. Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device. Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
    • Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. Android 修理キット
    交換用スクリーンやバッテリーの修理キット
    ショップを見る
    Android 修理キット
    ショップを見る
  4. Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  5. Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
    • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  6. Using the spudger, gently pry out the battery. The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
    • Using the spudger, gently pry out the battery.
    • The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
終わりに
2 の人々がこのガイドを完成させました。
Trevor Foster
メンバー登録日: 2010年04月18日
142 Reputation
3のガイドは作成済み
チーム
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S7G7
4 メンバー
6のガイドは作成済み
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 17
All Time: 9,761
