メインコンテンツにスキップ
TomTom ONE Back Cover Replacement
必要な工具と部品
  1. TomTom ONE Back Cover Replacement, Back Cover: 手順 1、 1の画像 1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Back Cover Replacement: 手順 2、 2の画像 1 TomTom ONE Back Cover Replacement: 手順 2、 2の画像 2
    • Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Back Cover Replacement: 手順 3、 1の画像 1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Back Cover Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Back Cover Replacement: 手順 5、 1の画像 1
    • As you can see, the battery and the speaker are still attached to the device and must be removed.
    • Using the spudger, carefully pry out both the battery and the speaker.
    • When taking out the speaker, the entire plastic shock mounting casing will come out.
    • The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
  6. TomTom ONE Back Cover Replacement: 手順 6、 1の画像 1
    • Once the battery and the speaker are removed, you now only have the back cover!
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Trevor Foster
メンバー登録日: 04/18/10
148 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S7G7
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 7,009
