はじめに
This replacement guide will demonstrate step-by-step how to replace the water supply line for your toilet.
Leaks or faulty water lines can cause costly damage to your home. It is best to replace any hardware concerns before they disrupt the functionality of your household. Most manufactures suggest to replace hardware every four to five years or earlier if needed.
Before using this guide, inspect the toilet and turn the water shut off valve to restrict the flow of water as shown in step 1.
必要な工具と部品
Before any work is done, inspect the hardware carefully and note any concerns. Locate the shut off valve underneath the toilet and turn it clockwise until it cannot turn any further. Do not turn past the stop point as this could damage the hardware completely.
ある他の人がこのガイドを完成しました。
コメント 1 件
I have a rigid supply line and afraid of damaging faucet because when I use an open end wrench it shakesi used steel wool on supply line to clean up - I used a metal brush on top of nut to clean it up I sprayed lubricating oil on suppply line going into nut and top of nut. Any suggestions?
