メインコンテンツにスキップ
Tivax STB-T9 Daughter Board Replacement
必要な工具と部品
  1. Tivax STB-T9 Daughter Board Replacement, Daughter Board: 手順 1、 2の画像 1 Tivax STB-T9 Daughter Board Replacement, Daughter Board: 手順 1、 2の画像 2
    • Locate Tivax STB-T9 and unplug device from power outlet.
  2. Tivax STB-T9 Daughter Board Replacement: 手順 2、 2の画像 1 Tivax STB-T9 Daughter Board Replacement: 手順 2、 2の画像 2
    • Remove the four screws holding the box together. 1 on each side and 2 on the back.
    • You will be using the same Phillips number 2 screw driver(bit P2 in the iFixit tool kit) for the all the screws removed in this guide.
  3. Tivax STB-T9 Daughter Board Replacement: 手順 3、 1の画像 1
    • Turn the converter upside down.
    • Remove the two screws connecting the face plate the the main box.
  4. Tivax STB-T9 Daughter Board Replacement: 手順 4、 3の画像 1 Tivax STB-T9 Daughter Board Replacement: 手順 4、 3の画像 2 Tivax STB-T9 Daughter Board Replacement: 手順 4、 3の画像 3
    • Once screws are removed, take off case by first pulling up on the back and then sliding away from the front.
    • When putting the case back on, make sure the plastic surrounding the power cord is not in the way or you won't get it all the way on.
  5. Tivax STB-T9 Daughter Board Replacement: 手順 5、 1の画像 1
    • Locate the white connector attached to the faceplate by black wires.
    • Place your forefinger and thumb on the sides of the connector. With little force, you should be able to pull the connector out.
    • Do not pull on the wire. This could pull them out of of the connector.
  6. Tivax STB-T9 Daughter Board Replacement: 手順 6、 2の画像 1 Tivax STB-T9 Daughter Board Replacement: 手順 6、 2の画像 2
    • Locate the daughter board in the face plate.
    • Remove the four screws connecting the daughter board to the face plate.
    • Make sure to keep separate the Daughter Board screws and the case screws.
終わりに
To reassemble your device please follow the steps in reverse order.
作成者
8人の作成者と共同で作成されました。
Olivia
メンバー登録日: 02/11/16
1 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-4, Burgess Spring 2016 Ohio State, Team 1-4, Burgess Spring 2016人のメンバー
OSU-BURGESS-S16S1G4
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 393
