メインコンテンツにスキップ
Timex T132 "iMac" Alarm Clock Battery Replacement
必要な工具と部品
  1. Timex T132 "iMac" Alarm Clock Battery Replacement, Battery: 手順 1、 1の画像 1
    • To prevent any injury, unplug the power cord from the outlet so the device is powered off.
    • Hold the clock so it is upside down. You should be able to view its caution labels.
    • Wedge the small tip plastic opening tool between the battery cover and the edge of its slot.
    • Firmly push against the battery cover (away from its outer edge) until it slides off of the base clock.
  2. Timex T132 "iMac" Alarm Clock Battery Replacement: 手順 2、 3の画像 1 Timex T132 "iMac" Alarm Clock Battery Replacement: 手順 2、 3の画像 2 Timex T132 "iMac" Alarm Clock Battery Replacement: 手順 2、 3の画像 3
    • Rotate the device so the clock's display is facing away from you.
    • Use the flat end of the spudger to pry out the battery.
    • Once fully lifted, grab the end of the battery and pull out the rest of the battery.
    • Do not remove the battery all the way because it is still connected. Doing so may result in damaging the power wires.
  3. Timex T132 "iMac" Alarm Clock Battery Replacement: 手順 3、 1の画像 1
    • Place the clock upside down on a flat surface.
    • Because the device is irregularly shaped, you may have to manually or externally balance it.
    • Grab the blue connector covering tab near the power wires and peel the snap connector off the battery terminals to disconnect it.
    • Do not pull out the snap connector and its wires because it is still connected to the device. Doing so may result in damaging the power wires.
    • Remove the battery.
終わりに
作成者
3人の作成者と共同で作成されました。
Tyler Price
メンバー登録日: 04/07/14
1,038 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014人のメンバー
CPSU-FORTE-S14S6G2
5 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 313
