メインコンテンツにスキップ
TiVo Series 2 TCD540080 Power Supply Replacement
必要な工具と部品
  1. TiVo Series 2 TCD540080 Power Supply Replacement, Removal of TiVo Series 2 TCD540080 Case: 手順 1、 1の画像 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Power Supply Replacement: 手順 2、 1の画像 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Power Supply Replacement: 手順 3、 2の画像 1 TiVo Series 2 TCD540080 Power Supply Replacement: 手順 3、 2の画像 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: 手順 4、 2の画像 1 TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: 手順 4、 2の画像 2
    • Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up.
  5. TiVo Series 2 TCD540080 Power Supply Replacement: 手順 5、 1の画像 1
    • Disconnect the hard drive power cable. Firmly grip the white power connector and pull away from the hard drive.
    • Do not pull on the power cables when disconnecting power connector.
  6. TiVo Series 2 TCD540080 Power Supply Replacement: 手順 6、 1の画像 1
    • Rotate the device 180 degrees and remove the two T10 screws from the power supply board.
  7. TiVo Series 2 TCD540080 Power Supply Replacement: 手順 7、 2の画像 1 TiVo Series 2 TCD540080 Power Supply Replacement: 手順 7、 2の画像 2
    • Remove the four plastic standoffs.
    • Use pliers to squeeze the plastic pieces on the head together. Carefully press down on the standoff and pull up on the power supply.
  8. TiVo Series 2 TCD540080 Power Supply Replacement: 手順 8、 2の画像 1 TiVo Series 2 TCD540080 Power Supply Replacement: 手順 8、 2の画像 2
    • Lift the power supply out of the unit.
    • Do not touch any circuit elements or capacitors on the power supply, as they may hold a charge after the unit has been shut off.
終わりに
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Svyatoslav Markeyev
メンバー登録日: 04/16/10
135 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S33G79
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 5,146
