メインコンテンツにスキップ
TiVo Series 2 TCD540080 Motherboard Replacement
必要な工具と部品
  1. TiVo Series 2 TCD540080 Motherboard Replacement, Removal of TiVo Series 2 TCD540080 Case: 手順 1、 1の画像 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Motherboard Replacement: 手順 3、 2の画像 1 TiVo Series 2 TCD540080 Motherboard Replacement: 手順 3、 2の画像 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Motherboard Replacement, Motherboard: 手順 4、 1の画像 1
    • On the rear of the device, remove the right screw with a T10 Torx Screwdriver.
    • Unscrew the two black screws on the left with a T8 Torx Screwdriver.
  5. TiVo Series 2 TCD540080 Motherboard Replacement: 手順 5、 1の画像 1
    • Disconnect the white ribbon cable from the motherboard.
    • The black base where the cable is connected is not part of the cable. Do not lift up on it!
  6. TiVo Series 2 TCD540080 Motherboard Replacement: 手順 6、 1の画像 1
    • Remove fan power connector.
  7. TiVo Series 2 TCD540080 Motherboard Replacement: 手順 7、 1の画像 1
    • Disconnect the hard drive data cable.
    • Use extreme caution when unplugging the connector and do not disconnect the data cable by pulling on the cable itself.
  8. TiVo Series 2 TCD540080 Motherboard Replacement: 手順 8、 1の画像 1
    • Disconnect the connector cable that goes to the lights on the front of the device.
  9. TiVo Series 2 TCD540080 Motherboard Replacement: 手順 9、 1の画像 1
    • Unscrew the four screws on the motherboard with a T10 screwdriver.
  10. TiVo Series 2 TCD540080 Motherboard Replacement: 手順 10、 3の画像 1 TiVo Series 2 TCD540080 Motherboard Replacement: 手順 10、 3の画像 2 TiVo Series 2 TCD540080 Motherboard Replacement: 手順 10、 3の画像 3
    • Use a pair of needle-nose pliers to make the two tabs parallel with the open slots.
    • It is recommended that you do not bend these back after putting unit back together as they may break after repeated use.
  11. TiVo Series 2 TCD540080 Motherboard Replacement: 手順 11、 1の画像 1
    • Pull the motherboard out towards the front of the TiVo unit, then pull up to remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Svyatoslav Markeyev
メンバー登録日: 04/16/10
135 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S33G79
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 4,414
