はじめに
This guide describes how to replace the hard drive.
パーツ
パーツは必要ありません。
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Lift the cover up and off the device.
    • Lift the cover up and off the device.
  5. Locate the hard drive.
    • Locate the hard drive.
  6. Remove the ribbon cable by applying firm pressure to the black tabs on the sides. Remove the power cable to the right of the ribbon cable.
    • Remove the ribbon cable by applying firm pressure to the black tabs on the sides.
    • Remove the power cable to the right of the ribbon cable.
  7. Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove. Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove. Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove.
    • Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove.
まとめ
Talha
メンバー登録日: 2011年10月11日
31 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 5-33, Amido Fall 2011 Cal Poly, Team 5-33, Amido Fall 2011人のメンバー
CPSU-AMIDO-F11S5G33
4 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,466
